Page 3 of 8
FirstFirst 1 2 3 4 5 ... LastLast
Results 61 to 90 of 230
  1. Originally Posted by larley View Post
    Try blocking the license URL?
    Yes, but after refreshing the page a new one appears.
  2. If the URL appears and is red, then it was successfully blocked.
    If not, then remove anything that looks like a token from the filter URL.
    Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2
  3. Hello, do you know why i get this message? Image
    [Attachment 81692 - Click to enlarge]
    Feb 2022
    Search the forum first!
    What checks have you run?
    Noob Starter Pack. Just download every Widevine mpd! Not kidding!.
    Oct 2018
    Scotland
    Just thought I'd take the time and thank you very much for all the work you've put into this A_n_g_e_l_a. Bit of a learning curve for me, was up until 4am trying to get Windows Terminal working, turns out I had to allow it through the firewall.
    Same with Python and with N_m3u8DL-RE. Python kept spitting out socket refused errors but after an hour or two of searching, finally worked out it was Tinywall blocking the connection.
    Helped me out no end completing a few season downloads with missing episodes that I just couldn't find on the usual torrent, nzb, IRC channels.
    Feb 2022
    Well done for sorting it and great to hear the script is helping.
    Feb 2022
    I asked Gemini AI about you and it said this:-Image
    [Attachment 81754 - Click to enlarge]
    I guess from your lack of response you've found your error and are too embarrassed to admit it. We've all been there.
    I now find the process of writing the question - making sure to add details, but then NOT posting, is enough. I leave it for a while. Then returning later I have ideas to try and experiment my way around what was a problem.
    Feb 2022
    There an update to the beaupy module 3.9.2
    The two earlier 3.9.0 and 3.9.1 didn't screen wipe after a user selection, the current update corrects this.
    'pip install beaupy --upgrade' will do it.
    If you are still on 3.8.3 there seems little point upgrading.
  9. Originally Posted by A_n_g_e_l_a View Post
    1. Try setting a lower resolution in the download option (480p for Amazon!)
    2. Try using Firefox browser - less chance for mismatch
    3. Upgrade the included L3 emulator CDM for a real-device CDM
    4. Try another site for the same video.
    Thank you for the ideas of what to do. It took me a while to hunt down what I assume is a real-device CDM L3 (I'm far removed from being able to tell for sure) since I don't own an Android device to dump my own.
    I tried it a few times with different CDMs from the repository I found, but I still have the same issue. I'm looking to grab the last three episodes of a cartoon for my sister before we lose our service... She's in love with the show.
    Is there anyplace to find the CDMs I need? Anything else I can try? Maybe there's a Firefox setting I'm missing... I'm sorry for essentially asking for hand holding help, but I've tried my best with the limited understanding I have to find the answer on my own. Thank you again.
  10. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Name of the show+season/episodes ? The name of the site would help too
  11. Hello how can i fix this error
    @A_n_g_e_l_a
  12. Code:
    MPD URL? https://webvodad-hamivideo.cdn.hinet.net/vod/hamivideo2/hamivideo-2546-2546104249_f_001/_/hd_6840-da-wv-all-ma-6sv2/hamivideo-2546-2546104249_f_001.mpd?url_type=&token=UtN_Tfymf7HjCG0VVXIuQw&expires=1725209889&content_pk=OTT_VOD_0000365771&content_id=365771&product_id=215803&serial_no=1710010042-77-03-66-82-13&auth_type=free&auth_by=google_101995749801834459581&sales_plan_id=&ts_id=&auth_login_id=google_101995749801834459581&device_os=win_&device_type_name=pc&chsm=48492b524d44e53fb9e16756f3902421&record_idx=1317608297
      File "D:\HellYesGui\allhell3.py", line 408, in <module>
        mpd_content = fetch_mpd_content(mpd_url)
      File "D:\HellYesGui\allhell3.py", line 64, in fetch_mpd_content
        response.raise_for_status()  # Ensure we notice bad responses
      File "C:\Users\Admin\AppData\Local\Programs\Python\Python312\Lib\site-packages\httpx\_models.py", line 761, in raise_for_status
        raise HTTPStatusError(message, request=request, response=self)
    httpx.HTTPStatusError: Client error '451 ' for url 'https://webvodad-hamivideo.cdn.hinet.net/vod/hamivideo2/hamivideo-2546-2546104249_f_001/_/hd_6840-da-wv-all-ma-6sv2/hamivideo-2546-2546104249_f_001.mpd?url_type=&token=UtN_Tfymf7HjCG0VVXIuQw&expires=1725209889&content_pk=OTT_VOD_0000365771&content_id=365771&product_id=215803&serial_no=1710010042-77-03-66-82-13&auth_type=free&auth_by=google_101995749801834459581&sales_plan_id=&ts_id=&auth_login_id=google_101995749801834459581&device_os=win_&device_type_name=pc&chsm=48492b524d44e53fb9e16756f3902421&record_idx=1317608297'
    For more information check: https://developer.mozilla.org/en-US/docs/Web/HTTP/Status/451
    URL:https://hamivideo.hinet.net/play/271044/OTT_VOD_0000365771.do?c=true
    Must be use Chinese Taiwan VPN can see it.
    I want to download this free The first episode,but reports error. I dont know why?
  13. Adding
    -H "Referer: https://hamivideo.hinet.net/"
    works for N_m3u8DL-RE
    Feb 2022
    ......but reports error. I dont know why?
    Error 451 indicates that access to the requested resource is unavailable for legal reasons, such as censorship or content licensing restrictions. ISPs or governments might enforce these blocks using simple network management tools that identify and restrict HTTP traffic.
    If it plays in the web-page the only difference to any 'legal issues' is we send the CDM details for an emulated Android CDM. Perhaps it needs a better CDM. Or maybe there is a one use token.
    The script is working correctly.
  15. We're not sending anything, this is a GET request for the manifest. Adding the header from post #73 works in combination with a chinese or taiwanese VPN.
    Feb 2022
    Ah! Yes, of course.
    Feb 2022
    [/CODE]
    If as Larkey says you need a header for an mpd you can modify the allhell3gui.py code temporarily.
    Towards the top of the code (starting line number 162) is a function fetch_mpd_content(url) . Modify it to look like the code below.
    PHP Code:
    def fetch_mpd_content(url):
    headers = {
    'Accept''*/*',
    'Referer''https://hamivideo.hinet.net/'
    response httpx.get(urlheaders headers)
    return response.text
    [Attachment 81909 - Click to enlarge]
    (Note my example is from allhell3.py)
    Remember to modify it back when finished.
  18. Hi A_n_g_e_l_a,
    i got three keys when i hit get keys.
    should i try to decrypt my video with every key to check which one decrypts correctly or is there any way to tell which is the right key?
    Feb 2022
    Originally Posted by edus View Post
    Hi A_n_g_e_l_a,
    After getting keys you do click the Download button? It should take care of everything for you and put all three keys in the download command automatically and do the download for you.
    Also, when downloading, N_n3u8DL-RE will show the key ID of each strream so you can identify which key goes with which stream.
    If doing it by hand just chain the the keys as below.
    --key xxxxxxxxxxxxxxxxxxxxxxxxxxxx --key xxxxxxxxxxxxxxxxxxxxxxxxxxxx --key xxxxxxxxxxxxxxxxxxxxxxxxxxxx and put them in the N_m3u8DL-RE command after the mpd and before --save-name a
  20. Thanks 32A_n_g_e_l_a,
    after getting the keys from gui, i ran N_n3u8DL-RE separately in my terminal as
    i just wanted to do --sv best --sa best and
    i didn't want to edit the py file.
    Its just a for a single movie,
    the kid matched with one of the three keys
    and it worked in decrypting the video file. 😊
    but what are remaining keys for?
    Feb 2022
    and it worked in decrypting the video file. ��
    For you and all AllHell3 users: If you go to a tool-shop and buy a chisel you'll find it sharp. And for some it will be good enough. But if you want it even sharper, polish the chisel back to a mirror finish, and then put an edge on the tool. You'll make it your own.
    The script you have is tool and it can be tuned to your need.
    If you find line 376 and edit it to as shown below
    [Attachment 81965 - Click to enlarge]
    It will automatically select the best video and audio.
    Three keys? Who knows why? - three resolutions perhaps? Who cares, so long as one key works?
  22. Originally Posted by edus View Post
    for other video or audio resolution (below --sv best --sa best)
  23. Member
    Sep 2024
    Singapore
    MPD URL:https://k-toggle.akamaized.net/edashncl/p/2082311/sp/208231100/serveFlavor/entryId/0_o...t/manifest.mpd
    cURL:curl "https://k-toggle.akamaized.net/edashncl/p/2082311/sp/208231100/serveFlavor/entryId/0_ofclqyno/v/1/pv/1/ev/1/flavorId/0_,rxutq0yj,e7gtu1ga,nl6o130n,dukwv2ut,/forceproxy/true/name/a.mp4.urlset/manifest.mpd" ^
    -H "Accept: */*" ^
    -H "Accept-Language: en-US,en;q=0.9" ^
    -H "Connection: keep-alive" ^
    -H "Origin: https://www.mewatch.sg" ^
    -H "Referer: https://www.mewatch.sg/" ^
    -H "Sec-Fetch-Dest: empty" ^
    -H "Sec-Fetch-Mode: cors" ^
    -H "Sec-Fetch-Site: cross-site" ^
    -H "Sec-GPC: 1" ^
    -H "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/128.0.0.0 Safari/537.36" ^
    -H ^"sec-ch-ua: ^\^"Chromium^\^";v=^\^"128^\^", ^\^"Not;A=Brand^\^";v=^\^"24^\^", ^\^"Brave^\^";v=^\^"128^\^"^" ^
    -H "sec-ch-ua-mobile: ?0" ^
    -H ^"sec-ch-ua-platform: ^\^"Windows^\^"^"
    Actual Video URL: https://www.mewatch.sg/watch/The-Unbeatables-S1-E1-42788
    When I tried to click download, the following message comes up:
    "invalid syntax (<string>, line 0)"
    What do I do wrong? Why can't I download the video?
  24. Originally Posted by chongjasmine View Post
    -H "Accept: */*" ^
    -H "Sec-GPC: 1" ^
    Copy the licence url (as bash)
    [Attachment 81975 - Click to enlarge]
    and paste
    [Attachment 81976 - Click to enlarge]
    Your key for 1st Episode
    --key 7be52e10b74372f3c31f4b6fff094e51:8a68f02d9ad5b9b2207f91ee7023b808
  25. Member
    Sep 2024
    Singapore
    Thanks, Karn.
    Able to download successfully now, thanks to your instructions!
  26. Member
    Sep 2024
    Singapore
    Another problem!
    Video Source: https://www.mewatch.sg/watch/The-Price-of-Peace-E1-55612
    MPD: https://k-toggle.akamaized.net/dash/p/2082311/sp/208231100/serveFlavor/entryId/0_zgdwt...t/manifest.mpd
    cURL: curl 'https://k-toggle.akamaized.net/dash/p/2082311/sp/208231100/serveFlavor/entryId/0_zgdwtm7n/v/22/pv/1/ev/6/flavorId/0_,afrrym10,kljo0jbw,/forceproxy/true/name/a.mp4.urlset/manifest.mpd' \
    -H 'Accept: */*' \
    -H 'Accept-Language: en-US,en;q=0.6' \
    -H 'Connection: keep-alive' \
    -H 'Origin: null' \
    -H 'Referer: https://www.mewatch.sg/' \
    -H 'Sec-Fetch-Dest: empty' \
    -H 'Sec-Fetch-Mode: cors' \
    -H 'Sec-Fetch-Site: cross-site' \
    -H 'Sec-GPC: 1' \
    -H 'User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/128.0.0.0 Safari/537.36' \
    -H 'sec-ch-ua: "Chromium";v="128", "Not;A=Brand";v="24", "Brave";v="128"' \
    -H 'sec-ch-ua-mobile: ?0' \
    -H 'sec-ch-ua-platform: "Windows"'
    There is no license source, so I used the MPD as cURL. Yet, a problem persists.
    Error message: Failed to extract or generate PSSH.
    What do I do wrong, this time?
  27. Originally Posted by chongjasmine View Post
    Another problem!
    First - I would stop cURL-ing the mpd url for the lic
    Second - The detailed solution to the "Failed to extract or generate PSSH" problem is explained in post #67
  28. Member
    Sep 2024
    Singapore
    Thanks.
  29. Originally Posted by A_n_g_e_l_a View Post
    Hi A_n_g_e_l_a,
    Hi A_n_g_e_l_a!
    Thank you for your great job!
    I have a problem.Allhellgui downloaded the movie, but no picture but sound.Allhellgui only shows one key. I tried Widevinefetch and it shows 4. I muxed them separately and it worked. Any idea why allhellgui doesn't show the other keys?
  30. Member
    Feb 2022
    Consider this: "How tall is the thing and how deep can it swim?" Can you answer that? Neither am I able to answer such unspecific question that need a specific answer.
    When tested on a reference site Allhell3Gui returned 5 keys.
    [Attachment 82040 - Click to enlarge]
    Normally bad-data in means bad-data out.
    Make sure your version is the latest (5) and you check you are using the correct data for mpd and license cURL. To date there have been a total 8255 downloads - and no-one else complaining about only 1 key.
